Converting from 3 point to 4 point.
What all is required to convert from 3 point to 4 point? Mainly looking for a parts list. think.gif
hahahaha!!!
Not much to them, front & rear engine plates, four (one for each corner) mounting blocks(for lack of a better word) that mount to the stringer...
Can't think of anything else?
might as well add the runners to it also , make it a lot easier to move or relocate the engine if you add something to the driveline , like a jetaway ..
Thats something to consider as well. If you couldn't find the stuff used or at a decent price & had to buy new, may wanna think about just gettin a rail kit. It would be nice to be able to slide the engine forward or back if you had to vs. pulling it completely out...
horsepower junkie
The rear mount on a 4 point is different than a 3 point. The rear 3 point does not have any place to bolt feet to go to the stingers, but you can most likely use the front one. The advantage of a rail kit is when you need to relocate the motor for what ever reason you can drill new holes in the rail and not your sringers  :smile30:
You'll have to get rid of the bellhousing mount from the 3 point set-up either way, with 4 point or rail system...
With it being a 1/4 stringer boat, doesn't seem like it has much room in the way of re-locating the motor with out major mods. I do think that the rail kit would distribute the load better. I wan't to get rid of the 3 point mount and like the Harmin system for OE parts seems like a good design. think.gif
Super Secret Squirrel Stuff! Must be a member of the Big Nut Tree Hugger Gang! :smile30:
See now I can tell you know GhostRider for sure, talkin about huggin big nuts & stuff, lol...
At any rate, I hear ya on the 1/4 stringer deal. You may find a 4 point deal fairly cheap from someone that has changed over to a rail system. As David said, you may be able to re-use the stuff you have on the front, just have to find a rear plate & the mounting feet/blocks... I'll look around, I find something I let ya know. :wink: :grin:
bang!
http://www.performanceboats.com/parts-sale/81570-~~~bbf-motor-mounts-jet-boat.html
If anything, the pics in that thread will show you what you'll need to make a 4 pt. system. :smile30:
Duanehydro said:
I have a set, without feet.....but it requires a reverse rotation bass akwards starter.
something about that phrase concerning tits on a boar hog comes to mind, lol... :cheesy:
