Now that i have had my boat out a few times, I got a few questions:
1. How should I setup the manual control on my diverter? Should the nozzle hang down a little (point down) at the bottom most position to help get on plane easier? I think it's set just straight back (I guess called "neutral position"?) I have to gas the fawk out of my boat to get it on plane, but it does fairly quickly get on plane, then once on plane I pop the control up to about midway and it seems to ride best that way, little roost just barely above the water while I am going, at least as far as I can see from inside the boat looking back while driving....
1a. Would you guys recommend to get a hydraulic diverter setup or should I just leave the manual?
2. Turning and gasing it hard... I did that Saturday, and the pump unloaded (maybe I needed to put the nozzle down first and forgot? I don't remember really) I had to gas the boat a few times to get the pump to load back up and go, in the process a big A$$ splash of water came over the back of my boat, I don't know how many gallons, but after about half way across the cove when I finally let off the gas pretty hard all the water came by my feet! I was like WTF? and kinda like oh shat, but since the boat didn't seem to be sinking I just got over to the shore quickly to check things and run the bilge pump for about 2 minutes or maybe it was like 5 minutes, and then all the water was gone and no leaks, just got the water in the boat from the big splash over the back.... Is this normal? Is there a limit to how sharp you can turn and then gas it or is something possibly not setup right and could be corrected? Or just operator error (yeah, im a jet noob for sure, LOL)
3. Typical cruising and top speeds... My boat is 19' fairly heavy I would say, dominator mb-12s with stainless impeller, not sure if it's abc, aa, whatever, don't know, wish I did, with ride plate, shoe, and loader, and Droop Snoot, motor is 10.5:1 or so 454 mild marine cam, big oval heads, dual plane with Edelbrock 850 carb. I got good GPS readings on cruising speeds, seems to be nice and comfortable and only on the primaries of the carb at 34mph, seems like if I go much slower the back of the boat starts to sag and nose comes up a little, it's just noticable anyway... Is that about a normal cruise speed? This is about 2800-3300rpm, It was hard to get exact readings, my friend was holding the GPS (I don't have a mount for it, just handheld deal) and the water was rough. Top speed I got was about 58mph, this at about 5000 rpm, and then my rev limiter kicks in, I finally adjusted it so now it's set to 5900 or so RPM, will test again when I go out next time. With the motor/pump/boat setup I have not knowing what the impeller is, just that it's stainless, what should be the top speed on it (roughly of course) and if it's not up to par, then where should I start looking to adjust things so I get a little more out of it? Not that it's not fast enough for me, it is, but the rev limiter thing was very annoying while trying to top out the boat, the motor has way more in it with the current setup than 5000rpm, it's all new crank, standard, no undersize, rods were all resized and ARP bolt kits, and the engine guy told me I could probably spin it to 6500 without it coming apart, or stacking a bearing, though I'm not interested in that, but am interested in 5500 or so. Maybe I need a different impeller, I don't think the impeller to wear ring gap clearance is a problem, it was recently redone by the Snowman before I got the boat and don't have many hours on it after the install of the stainless impeller and new bronze (i think) wear ring... Could be wrong on that one, it's whatever the expensive shiz is.
Sorry for the long A$$ post, just trying to figure all this stuff out, the boat has been a blast so far, just trying to learn a little more about it and make sure it's setup right. Thanks in advance for help!
