Looking for a couple of things
Aqua Geek
I need the following:
White face GPS Speedometer
Throttle linkage setup for a sideways mount dual carb setup on a Weiand tunnel ram on a BBC. (Holley 660's if it matters)
Also, where can I get aluminium polished diamond plate at a good price in the DFW area?
77Jet Star
Speedometer check these guys out http://www.speedhut.com/custom_gauge_description-gauge_type-Speedometer-auto_number-766.htm Got my sideways linkage at Summit.On the plate you might try a big truck (18 Wheeler fab or Rigging shop) they use a lot of that stuff and throw the cut offs in a scrap bin usually.I think A used speedo or linkage may be a tough find.    :smile29:
WAFOBABY
depending on how thick you want and how much I can prob get you some polished D plate give me a call I will ck with my brother and see for sure.
I am not in Dallas but I have some I am planning on using on my Chopper project definitely will have some left over.  Hmm now that I just thought about it a Polished Diamond tread plate aluminum dash might look pretty awesome.  Dang I gotta quit thinking.
HellinnFrnt
the reflection will cook your face ....
What brand of GPS and what speed requirements are needed.  Do you need both the GPS head and the antenna or just the head?  Do you need speed recall?
77Jet Star
Check out these guys they will make any color combo you want in a gps  http://www.speedhut.com/custom_gauge_description-gauge_type-Speedometer-auto_number-766.htm
Aqua Geek
I need both pieces of the GPS Speedo. Up to 100 is about all i would ever need. As far as recall, yes or no, doesn't matter. Just looking at the cost. That is why i am trying to find a used one.
As far as the plating, I want to cover the steps on my trailer. Four pieces about 12" x 24". Not much but at Lowes They want $25 a piece for that size. Kinda steep in my book.
I cut out and installed a polished diamond plate dash. Looked awesome. Bad glare, washed out the gauges so I took it off. I would advise against it unless it is inodized or something to cut down on the glare it would make.
Thanks everyone.
WAFOBABY
Hey bobby if that is all u need i have what u need u can have it if u come get it.  I had a diamond plate tool box that the top broke so i took it off my truck so i could take and cut peaces out of it for different stuff ur more than welcome to it.  But just fiy.  U might want to have the chrome or power coated clear after u clean them up. Cause the lake water will make them dull quick. Ask anyone who has a polished pump. Let me know  :smile17:
Aqua Geek
That would be awesome! I need to run out there anyway to get the carbs to you. Busy this weekend?
