jimmyray0682
Thinking I need to upgrade to a double pumper
jimmyray0682 said:Thanks guys. I took the boat out today and sure enough yall were right the secondaries were not opening. When I manually opened them it was a whole new boat. I put the boat where it was just under plane and opened the secondaries and it immediately planed out and took off. So I'm gonna order a new diaphragm and see what happens.
jimsplace said:The weaker spring is letting the secondary open too quick. I don't think the vacuum operated secondary has squirters to cover the increased air without fuel.
It's largely a matter of trial and error to see what it likes. It will tell you.
DISTURBED said:I would throw some more timing at it just to see if it likes it. I'm betting it would like 38-39 total.
Patchman said:Your prop ia also gonna dictate what you can spin WOT. Sounds like you have the carb figured out though! clap.gif
customtouch said:DISTURBED said:I would throw some more timing at it just to see if it likes it. I'm betting it would like 38-39 total.
While it is possible it might like that much timing, I would be very carefull to monitor the motor closely for signs of detonation. IMO (which is almost worthless compared to Tim's mechanical knowledge) that sounds like a lot of timing for a basically stock 350 running on 90-93 octane fuel under the constant load found on an outdrive type boat. Mercruiser recommends 32 degrees total maximum if you go by the chart and add intitial. I ran 10 degree initial and about 32 total on the 350 in my Glastron with 93 octane and it seemed to like it & I felt pretty safe. The problem with an enclosed engine compartment is you can't really hear a problem if it's knocking a little until it's too late so just pay attention if you kick the timing up that much.
