Small Block 350
need a bit of info,  I'm helping a friend with his small block,  I need to know what spring pressure to use with this cam,
CS XR 270 HR -10
CAM SPECS;  INT  EXH
ADV DUR.    270  276
DUR@  .050;  218  224        LOBE SEP 110
VALVE LIFT    .495  .502
CAM IS HYDRAULIC ROLLER
he's got some heads that are double springed,  and looking at another set also
do not know the spring pressure of them as of yet,  but I'm looking for a info
That's a small lift cam should not need the double springs that would be overkill.
I don't have a clue on the spring pressure but should be moderate with that cam.  IMHO a good set of stock springs would work as long as they are not worn out abused POS's
oldbuck40
CS XR 270 HR -10
CAM SPECS;  INT  EXH
ADV DUR.    270  276
Comp book says use spring kit 986-16 (2) requires machining on heads seat load is 132@1.750 open load is 280@1.250    Rate (lbs./in.)296
Negative.  That's a pretty healthy little cam.  The lift and duration are right on the requirement boarder line.
oldbuck40 said:
CS XR 270 HR -10
CAM SPECS;  INT  EXH
ADV DUR.    270  276
DISTURBED said:
oldbuck40 said:
CS XR 270 HR -10
CAM SPECS;  INT  EXH
ADV DUR.    270  276
that's what a found at summit,  now it looks like I can compare that to what he has, and maybe they will work,  getting some good info,  but CJ go work on your boat
oldbuck40
KONA said:
DISTURBED said:
oldbuck40 said:
CS XR 270 HR -10
CAM SPECS;  INT  EXH
ADV DUR.    270  276
clap.gif if you need any other info outta that old book i got just holler,,its got tons of stuff listed in there,,course its probably on line but who knows?
When it came to production heads for that sbc, I think there for awhile people were using the Vortecs. Should be pretty cheap by now. :smile30:
