my 81 youngblood resto!
oldbuck40
DISTURBED said:
Finish?  As in go to the water finished?  Or, start on the next minor project finished?
Well some of the stuff thats coming in UPS is causing me to wait on the plumbing issue. you know this will be in the way of that and so on,,,,So yea other than plumbing and cables im just about done!
oldbuck40
Ok well after several trial fittings and making all the brackets :rolleyes: the right fuel has found a home!!! LOL Geeze what a biatch!  Sender and gauge tested out good and all the electrical checked out as well this morning. Off to install the left tank now,,hopefully it will go faster than the first.
Also heard a comment about CJ and a cap???? Whats the status on him and his boat?
Cool!  I'm glad to see you're finally gonna get to use that gem.  When are we going to Steele Creek?  Any water there?
oldbuck40
its probably low as usual! 13 plus down
oldbuck40
Devilman said:
damn, already? thought it was usually a little later in the year when it started gettin that low...
Hell it never really came up if any at all! The people that control the Brazos have contracts to sell water to the rice farmers way down south,and there hasnt been any good rains to speak of in the last few years,so until it floods it will most likely stay the same level or lower.
oldbuck40
Another daily update!!!  Spent 2.5 hrs chippin away at the spray foam up in the bow just to get the wires up to the bow light!!! Had to take a 9 ft piece of inch and a half pvc pipe sharpened on the end and make a tunnel thru the foam up to where the light is mounted now,,damn it took forever seems like. Well once we figured out the pvc was right under the light i took a smaller piece of steel 1/2 in. conduit stuck it in the hole and then with the air blower i blew some light string up the pipe till i could see it below the light,,used a small wire hook pulled the string out and tied the wires to it and pulled them back thru. Talk about lucky,,i doubt that would ever go over smoothly again lol!
All diverter hyd. lines came in yesterday as did the little bit of chrome stuff i had done,,and the chrome stuff that Airline plating did came out really good! bling.gif
So im off to get the lines put on then mount the hyd pump and call that good!
That is some tedious chit isn't it.... Nice that it all turned out on the first go-round, coulda had the grandson scooch up in there though if worse came to worse. :cheesy:
Definitely won't be long now, its almost all ready to cover up & put back in the barn. :grin:
oldbuck40
lmao Hell man there aint NO like (0) room in the bow,,foam is all the way up to the top! We just got lucky shooting in the dark!
oldbuck40
Hyd. Lines and Diverter pump done! Forward/rev. Cable going in, throttle cable after lunch! Then it's time to go get plumbing parts!!!
WFO
Get her done by Jetfest and bring her. We will have to have special parking for all wingers.  jump.gif
