When I was a Deputy, our Department highly recommended Glocks. I have a Glock 22 ( full size 40 cal ) and a off duty Glock 27 ( small frame 40 cal ). 40 cal is a great all around ammo, but prices keep going up, so painful to practice on the wallet. Glocks of 40 cal and up have larger grips as most brands, especially is a double stack magazine. If you have a small hand, go with a single stack gun. Not as wide. The 9mm Glock is a wonderful weapon, easy to shoot, and simple to clean. 9mm is decently prices and a good all around caliber. I only recommend the generation 3 Glocks thou, not the Gen 4!!
I also have a Beretta 92 -9mm ( old military sidearm ) and a 70 series Colt 1911 (.45). Of all the guns Glocks are the easiest to use in a panic situation as they just have a trigger lock. Pull the trigger and it shoots.
Revolvers are a great home defense weapon. If you get a misfire, just pull trigger again.
Anyway, do your own homework and get the gun that works for you!!!
My .02 is just worth .02. :smile27:
