jimsplace said:Isn't it wonderful how more power is required to fix, just about everything in a boat?
Yea I agree with ya. Between Jerry(vdrive video) and JJ and my determnation should hopefully get it all taken care of.Jerry has the exact same boat as me :smile15:vdrivenman said:on a flattie set up has as much to do with the boat taking a set and carrying the nose as power. i totally agree you have to have enough power to carry the nose of the boat first,but the right % gears and motor placement are key factors into a good running boat.
that's gonna run realllllly good man :smile15: you ready for another trailer project? , i got 1 that's hurting for a make over :smile17: i'm just can't bring myself to even start on that or pull the hull offa it :smile14:pro53 said:Well picked up my BBC blower motor this weekend.Will take it apart and go through it , the guy said it was running when pulled, must have been along time ago though.So far what I have discovered in the motor:
block# 3963512 4 bolt main 69-71 year
rectangular port heads# 3994026
Aries blower pistons
steel crank
blower hub
crane rollers
miildon gear drive
cam?(havent checked yet)
671 dyers street charger
2 650 holleys( will be running 750 dps)
nitrous plate system with solenoids and lines
Will most likely run the same blower cam Tom was running.
Well got a good start to a fast motor for the FLATTY :smile15:
IMPATIENT 1 said:keep it man, you'll get used to the boost fast and want more, trust, been there. i had plans for a 200hp shot on my blown 475 for last labor day but in june i had a oil pump failure take all my extra $$$ i had saved for the nitrous set-up.
most of the blown boats these days you may end up racing will have nitrous too :smile12:
:smile17: :smile23: just tellin him the truth, lots of blown boats run nitrous too these days.coolglastron said:IMPATIENT 1 said:keep it man, you'll get used to the boost fast and want more, trust, been there. i had plans for a 200hp shot on my blown 475 for last labor day but in june i had a oil pump failure take all my extra $$$ i had saved for the nitrous set-up.
:smile17: Peer pressure at it finest!!!!! :smile19:
:smile15: it'll damn sure cool the intake charge alot, make more power thataway too, so 100hp might end up yielding 150hp more :smile12: the mag shouldn't have any trouble lighting it up , just keep plug gap little cause cylinder pressure is gonna be high :evil: don't wanna be blowing out the spark before it can ignite the fuel charge :smile12: 1 of my homies runs 30lbs+ of boost and a 350hp shot and he couldn't run a msd box due to that happening to him, put his ole mag back in and never had that trouble again.mag's have less voltage, but the current is what counts :wink: kinda like home electricity, the high voltage may not kill ya, just knock ya silly, but a high current circuit will fry yo ass.pro53 said:A 100 shot wouldnt hurt anything :smile20:
