spd500 said:
http://www.texashotboats.com/forums/index.php?topic=12336.0
Looks like he is running a 10 SI with a serpentine pulley there James.  Might see if he can get you a better pic of his mount.
Actually you can see it pretty well here if you look at it full size and not THB tiny size.
http://i429.photobucket.com/albums/qq12/FormulaZR/LS1%20Liberator/DSC04045.jpg
Yeah, it's a 10-SI for sure. It also looks like a low mount will hit the stringer. I can probably pivot off the head and use the lower bolt hole for the adjustment rod. I'll figure something out.
This is the proper Pinouts for the 16-Pin OBDII Connector:
Pin 2: Diagnostic Signal Wire, this is the Serial Data Wire from the PCM.
Pin 4: Ground
Pin 5: Ground
Pin 16: Constant Power from Battery
FormulaZR
Here's some pics of an LS1 in my old Horizon V-hull. Also, these are the same motor plates that are in the Liberator; and the alternator is in the same basic location - but the plates were cut down a few inches for a "deeper" installation.
That is the same alternator that I am planning to run on mine . I was kinda thinking I would try to mount it from the front motor plate and have an adjustable arm go to the head .
That is the same alternator that I was going to use on mine , but I was thinking I would try to mount it to the front motor plate and have an adjusting arm come from the head .
LOL double post
