How about paint the valve cover, coil packs, and brackets to match the boat's paint job and display your LS power with pride! Here's a couple of examples. Looks a whole lot easier to pull off too.
Sharkbit said:go with this
http://www.mastmotorsports.com/2010/news-view.php?id=60
blazeracer said:Gonna need some metric to NPT adapters for the gauges to work. Found a place that sells them.
http://www.discounthydraulichose.com/9235_Metric_x_NPTF_Female_p/9235.htm
You will need a M16x1.5 Male Metric x 1/4" Female NPTF for the oil sender and a M12x1.5 Male Metric x 3/8" Female NPTF for the water temp sender. The oil adapter goes where the stock oil sender goes and can connect directy to your gauge as the computer doesn't use this info at all. The water sender has to go into the opposite head as the other water sensor because the stock one does send info to the computer.
spd500 said:I still need to find exhaust for mine. I will either build some, or order the logs from Australia if I don't find a better option soon.
spd500 said:I really want log type exhaust , because I plan on adding a few turbos in the future and don't want to have to change the exhaust when I upgrade .
spd500 said:The guys running the twin turbo setups over on Preformance Boats have been having problems with too much heat in the headers , thats why I was thinking logs . Might be a better setup , not sure .
spd500 said:Headers getting too hot to be that close to the fiberglass . I know Haas had to build heat shields for his because it was making so much heat .
