The South is sure quiet!
Duanehydro said:
make sure the cooling system is full, sounds like the heater core is partially plugged.....check to make sure the 2 heaters hoses going to the core are about the same temp, in and out.
Both lines on the heater core are hot, if there was any temp. difference between the 2, I couldn't tell. The coolant tank level is down below the line, I'll add some to it & try it again later, see what that does.
Lemme guess, thats how many digits are in the part number for a heater core for sayyyyy.... a 2003 Dodge?  :grin:
Patch hopped in, took a look around and figured out this place is vacant. So he then peed in the corner and left! :smile16:
ChryslerJet said:
Eww so that was what I smelt when I came in
This is a third person thread Patchman says!  :smile30:
DISTURBED said:
Disturbed is happy to see Patchman playing by the rules.  Even if he does piddle on the carpet.  clap.gif
Patchman is always an  :smile14:, just ask him! :smile30:
Knotty said:
ChryslerJet said:
Knotty said:
ChryslerJet said:
Well cant work outside on the boat or chopper.  No garage to work in. No other indoor projects.  At work bored guess I am here then. jump.gif
Pics of Chopper please.
Knotty Just for you here is where it is at as of last night.
Thanks, its nice to see it back into a rolling Chassis with proper alignment and the rake I envisioned after a long 15 year wait.  Next to get done the motor mounts so I can get that mounted up then replace the few parts on the motor that need it and go through the carbs and get her fired up.  mount the handle bars, wiring, seat and controls and see if I can ride it around a bit will be giddy as a ... well hell I don't know when that happens.  Hoping to later on get a 21" front wheel instead of the 19" I have on there now.
Disturbed finds CJ's post disturbing.......  This is a third person thread.  :wink:  Typing in 3rd person is a challenge but, it can get pretty funny too.  Carry on...  crazy.gif
Devilman said:
Awful low to the ground.. Devilman thinks its cool... he also wonders what it started life as?  :cool:
CJ says that the bike started like as a 78-81 Kawasaki KZ 400LTD. CJ bought it with a modified front end where someone welded over the top of the KZ neck a Neck from a Honda CB750 and welded some really bad extensions on the forks.  CJ cut off those extensions and welded 1/4" thick dom tube extensions with sleeves which should make them stranger than the original forks.  CJ also cut off the CB neck then Cut of the KZ neck and also cut off the twin down tubes bent them out to the front and intowards the center.  CJ welded back in the CB750 Neck in the position its in now then welded in the new 2" down tube made of 2" x.120" DOM tubing. CJ also made the rear struts to go in place of the shocks that were not existant at the purchase of the bike.  The original 400 motor has been replaced with a 500 motor from a kawasaki ninja sportbike.  The motors were virtually identical in dimensions.  With the neck fitting at such an angle and so close to the frame CJ needed to modify the front inset of the tank to fit around the neck. CJ still has a lot of work to do but this part was a major hang up for him over the past 15 years since the old neck was not welded on straight nor was it at enough of a rake angle for his taste and the look CJ wanted for the bike.  When CJ gets home he will measure the length of the bike.  It is a very long bike and probably won't fit most bike trailers.  CJ's nephew has told him that he needs to stretch the rear out 2-3" as well and CJ has thought about it especially with the seat CJ has planned with the sissy bar as well.
