Bracket Racing For Boaters.
Carnivalride
HammerDown said:
Motor Head said:
im hoping to impeller  mine to turn 6200-6500rpm WOT. I hope a B impeller will do the trick?
Buy the impeller that let's the motor rev to its max horsepower and torque. If it 5600 or 8500, then build the bottom end accordingly.  RPMs kill engines
Cam choice is critical
HammerDown
Carnivalride said:
HammerDown said:
August 6th this year
REALLY??? Now that doesn't interfere with Spencer's birthday this year.  clap.gif
Yeah I actually did a little research this year on picking the date.  Got it between sdba race dates too. So might get a few more folks that would normally be racing or helping on race teams.
We aim to please here in the OHBA. ...lol
Carnivalride
You might actually be able to witness one of those 63.8 mph passes you keep calling BS on. lol  :grin:
Carnivalride said:
Carnivalride said:
                          KILL SWITCHES MANDATORY
SKI BOAT                              OEM BOATS ONLY,COVERED MOTORS, ON PERFORMANCE MODS
BASICALLY STOCK          SINGLE CARB UNDER 850 CFM, V-HULL ONLY, ANY EXHAUST OK,
                                                NO SOLID LIFTERS, NO ROLLER  VALVE TRAIN, STOCK HEADS ONLY
STOCK TUNNEL                SAME AS BASICALLY STOCK, TUNNEL HULLS ONLY
SUPER STOCK                  NO DOMINATOR CARBS, TUNNEL RAMS OK ANY VALVE
                                                OK, ALUMINUM HEADS OK, ANY V-BOTTOM TX19 OR TUNNEL
                                                HULLS OK, NO HYDROS
PRO STOCK                      FUEL INJECTED, MULTI CARB OK, NO BLOWERS, NO ALT
                                              FUEL,ALUMINUM BLOCKS & HEADS OK
MODIFIED                          NITROUS &  ALT FUELS OK, NO BLOWERS OR TURBOS
                                              NO 2-STROKE HYDROS
SUPER MOD                    BLOWERS, TURBOS, 2-STROKES ALLOWED, NO 2-SPEED
                                              HYDROS, NO SINGLE SEAT  RACE HULLS, NO NITROS
PRO MOD                          BLOWERS, TURBOS, 2 STROKES ALLOWED ALT. FUEL OK
BLOWN FUEL                  NO 2-SPEED HYDROS, NO SINGLE SEAT RACE HULLS,
                                              HYDROS OK
ELIMINATOR                    BLOWER VS. NITROUS BOATS (BLOWER BOATS MAY NOT
                                              HAVE  NITROUS BOTTLES IN  DURING RACE)
PRO ELIMINATOR          NO BLOWERS , NO TURBOS, NO NITROUS, FUEL INJECTION
                                              OK, ALT FUELS OK, ANY  HULL OK
UNLIMITED JET                JET PUMPS ONLY
UNLIMITED TOP              RUN WHAT YOU  BRUNG!!!!!!!  THIS CLASS WINNER TAKES ALL!
FUEL
CLASSES WILL BE RUN IN STAGGERED ORDER AND OR IN CONJUCTION  WITH OTHER CLASSES SO THAT MOTORS  WILL HAVE
TIME TO  COOL.  IF YOUR  BOAT NEEDS THESE REQUIREMENTS THEN PLEASE NOTIFY  AT REGISTRATION.
ALL BOATS ARE SUBJECT TO INSPECTION BY JUDGE OR OTHER DRIVERS. BOATS DEEMED TO BE TOO FAST OR SLOW FOR
A GIVEN CLASS MIGHT BE MOVED TO ANOTHER CLASS BY FIRST CONTACTING ONE OF THE OFFICIALS AT THE
REGISTRATION  PAVILLION. ALL PROTESTS OF ANY BOAT NOT DEEMED WORTHY OF BEING IN A PARTICULAR CLASS
WILL HAVE A VOTE OF ALL THE DRIVERS IN THAT CLASS WHICH WILL BE CONDUCTED AT SATURDAYS DRIVER MEETING
THE OFFICIAL WILL BREAK ANY TIES: DRIVERS ARE RESPONSIBLE TO MONITOR REGISTRATION BOARD AT PAVILLION
TO KNOW WHICH BOATS ARE IN THEIR CLASS AND INSPECT THEM BEFORE THE DRIVERS MEETING.
NITROUS BOTTLES  MAY NOT BE IN BOATS UNLESS PERMITTED IN THAT CLASS OTHERWISE SUBJECT TO DISQUALIFICATION
FOR THE CLASS ENTERED.
DRIVERS & PIT CREW  NO DRINKING, BALISTIC SHORTS HIGHLY RECOMENDED & HELMENTS
Loren , what the cost ?? .. i think I would fit in in the Modified bracket .. I think this is about 4 hours from home for me .. Might make it one of these years .. Don;t think I will  make this year , too much money being spent on the new engine ..
Prostock and lower was $50, they raced their prices on the upper level classes but I don't remember what it was. IF you removed the nitrous bottle you'd probably run Pro Stock
No Nitrous in the boat anymore .. But I run E-85 and I bet they will say that is ALT. fuel .. Can you run race fuel and be in that class? What is ALT Fuel ??
I need to run in the 70 mph class so I can keep up . with the GREEN ENGINE , I need all the help I can get ..
They need a class called Super Ski..  Stock looking boat with engine cover and thru transom exhaust, any mods you can stuff under the hood.
Carnivalride
I'd still say Pro Stock because it is "pump gas". Even though E85 is not 100% gasoline it is available at the pump and contains about 15% regular unleaded gasoline. They bend/flex the rules for all kinds of crap trying to make it competitive and from what I've seen in NA I don't see any performance advantage in running E85 vs VP C-14 or something like that.
Now I also wouldn't go out and volunter that you run E85 either.
Face it if I have to race totally aftermarket big inch engines in Super Stock what's the big deal about E85 for fuel?
Right now the E-85 is 2.65 a gallon and C-114 is about 9.00 a gallon .. Plus I have a Dominator on it
The E-85 is good up to about 14 to 1 compression and it cheap ..
I would just run it and tell them it is pump gas ..
HammerDown
Well by slowest jet boat there I actually meant me. We could hookem up and see who leaves the biggest snail trail.
Carnivalride
HammerDown said:
I get my gas out of the pump......at Henryetta air port. So really its "pump gas" right???
They don't care about gas whether you run 87 octane cat piss or C-12. Nobody's ever questioned me on my fuel there.
So tell me snail trail you have a 540 and you're running av-gas? And you have the nerve to accuse me of sand bagging. lol  think.gif
HammerDown
Well you never asked...and I never volunteered. Its all in the wording :smile16:
Carnivalride
So I'm asking now, what heads, and what cam and at this point I'm assuming it's a roller Mr Sandbagger. lol
HammerDown
540 Merlin 2 with dart pro 1 heads. .660 solid roller with rev kit. all studded and girdled. dart single plate for dominator, 1050 holly hp. thinkin about switching to alky cause the compression is up there. guess at 13:1?? The guy i bought it from was a member here on the boards a couple years ago out of Altus OK. He told me the motor was built in the DFW area. its all there.
You know dude, probably about 425 hp, nothing to wild
Carnivalride
LMAO, yep and my poor ole deal makes about 190hp too.  Sounds like it should run pretty well if the boat is set up. I know the video you keep refering to shows a that has considerably less motor than you have.
What about converting your dominator to E85?
HammerDown
Its just not that available around here. Closest place is Glenpool and thats about 30 miles north of my house. I work in Tulsa about 2 blocks from Gran Prix and I could just buy methanol by the drum and keep it at the house. Our buddy WildHair is switching his over to E85. Plus, I have a buddy that will swap me my dominator for his alky dominator. Just have to spring for the fuel system swap.
I'm going to get after getting the pump set up good this winter/spring. It was really sloppy last summer. Just seems like the more I dig the more I find wrong. We'll be there though this summer.
HammerDown
And my hull is pretty heavy, its definatly not a light layup. And its a little disheartening when Ervin Capps tells you that you'll never be fast.....LOL
Carnivalride
Well I'm not that up on jetboats but for me weight hurts ET far worse than it does mph. I can give a 200lb passenger a ride and it'll be within 2mph of what it'll do with just me (per GPS). On the other extreme filling both saddle tanks will kill 2/10ths at the drags (I used to do that when I needed to slow it up).
I also believe you can fly a brick with enough thrust so why don't you lean on that 540 a little.  :grin:
