The Anger Sanger!
SPD said:
Hey  whatever.gif Mine is finished  think.gif The Sanger was going to be ready to go in April  hurry.gif hurry.gif hurry.gif hurry.gif
Yep, just in time for Tawak! I wonder what condition the CJ will be in when it shows up there?
It's all good, get that LS running and by that time I will have something ready for ya! :smile30: :smile16:
Just sayin'  :smile30: So , you ready Patch  think.gif :smile21:
I never ever ever said the Sanger would be ready in April. But I could pull the motor out of the farm truck and get some work done. But that wouldn't be much fun, so it will get a new mill and some lipstick! :smile30:
Who said anything about a Hawaiian? I'll be ready come April, will you? think.gif Mite want a bigger shot, but you better put some good slugs in it, because when they make real power with NOS, those crappy pistons like to say see ya! :smile20:
Yeah you did  :smile30:
That was before you got the fish slayer , but I guess you  might have been planning on getting it back then  think.gif So what's up , you wanna line up with the fish slayer ?  :smile16:
I think I need a bigger prop on the fish slayer, it cavitates real bad on the top end! think.gif
The Hawaiian is still running! You have to beat it first! :smile16:
Hey I will run the Hawaiian and I know you will win.  Just load it up with some topless hotties and I will drive behind you all day long.  :smile16:
Lol , its all good . Still get a trip to the water out of the deal . It might outrun my little LS motor anyway , you just never know .
Boating is good either way you look at it! I'm actually putting a smaller carb back on the Hawaiian, it will be much happier with it's 600 cfm back on there! :smile14:
Lol , Yeah if I were you I would probably start finding excuses too  think.gif crazy.gif :smile30:
Actually I think it was faster with the little carb! No excuses in my camp! I've seen 54 mph with that carb! :smile16:
OK, now it's paint question time! This poor boat has been painted multiple times from what I can tell. I guess I need to sand down to the gel and seal that correct? What grit should I use that won't cause a million scratches? I'm not into that chemical stripper stuff. Also I have that real skinny Sanger rub rail. It's not real bad, but thinking about deleting it! How much of a pain would that be? think.gif I'm not planning on keeping this boat, but I want to do it rite! :smile16:
Sand it completely to gel. I used 60 grit for stripping . Some primers have sealer some don't , ask customtouch what is best to use . I used PPG medium build . Capping the rub rail is not that big of a deal , but it will add a lot of sanding and body work to get it right . I would just put the rubrail back on it , half of the boats I have seen that were capped cracked later anyway .
It is hard to give exact advice of what I would do without actually seeing the boat but Spd is correct that you should sand it down to the original gel if possible. I normally don't like to use any thing more course than 100 grit when sanding on fiberglass but if the paint is that thick, then I will use 80 grit on a da to get the biggest part of the paint off. As soon as just a little of the gel starts showing through I will switch to 100 grit and finish stripping with a block. This will keep from putting too deep of scratches in the gel that might come back later and will also help straighten the fiberglass. After that I will normally go over it again with 150 or 180 grit before I prime. You should prime and re-sand before painting. As far as the primers go, that will be a matter of choice since I think most any medium build, catalized urethane primer will work. The main thing you have to be carefull of is that no "raw fiberglass" is exposed before you prime with any urethane primers. It all must be cover with either putty or a polyester primer or it will print back through the paint later. Also polyester primers and fillers (automotive bondo's) are not recommended below the water line. To be safe and "right" you should use a Vinyl Ester putty for any repairs that will be submerged. Hope this helps but if you would like for me to go into more detail, feel free to give me a call.  512-423-7889
That's what I did , but I did 60 instead of 80 grit . I did 60 until it was close and then 100 to get the rest of it . I am not sure what PPG primer I ended up using , but I went over it all with Customtouch back when I was buying the primer .
Becket
sturat said:
INTAKE LIFT=.562"
EXHAUST LIFT=.588"
INTAKE DURATION @ .050"=234 DEGREES
EXHAUST DURATION @ .050"=244 DEGREES
I have a hydraulic roller that is almost these exact numbers that I will let go cheap. I do not have the lifters but the cam is brand new. Made three dyno pulls then it came out and i went to
.659 .659
.248  .254
.303  .309
LB 110.0
Becket
Gas-Hole said:
sturat said:
INTAKE LIFT=.562"
EXHAUST LIFT=.588"
.659 .659
.248  .254
.303  .309
LB 110.0
Done it again! Need to watch where the little flashy thingy is! So...............What are the numbers and whats your price?  think.gif
