COONASS said:Duanehydro said:should be bolted-through the intake w/ high grade bolts, and nutted on the backside. don't forget the silly cone.
do they make a grade 8 bevel head :smile21: or do you guys have a hex bolt head stick'n down :undecided: I can't find any wit bevel heads
COONASS said:Duanehydro said:my local bolt store has em....grade 8
good to know ........I need 4 :grin:
Gotcha, I'll see if I can make it by there.
You wan to simply open the end of what's there...drill trough w/ a small bit, carefully enough not to damage the original threads, and finish-tap it.the bolts need to be threaded as well as nutted.spd500 said:When you drill all the way through the intake do you tap the hole , or just stick the bolt in and nut it from the top ? Seems like you would want to tap threads into the hole and tighten the bolt in and then nut it , but just wondering ?
