blazeracer said:I was debating whether to get a motor only or one with the harness and puter.. After reading your info I think I'll go with motor only and get the right harness already made. What PCM would be the best to use?
Motor Head said:Did you put the small cam back in that motor James?
blazeracer said:So I send the stock harness to someone like this guy and he makes it stand alone, adds a fuse block on OBD-II port for $225? That's what I need then?? Great info! I'm thinking DBW from the get go too will make life easier. Are there 02 or 03 models that had it?
http://www.ebay.com/itm/wiring-harness-rewire-service-ls1-ls2-6-0-5-3-swap-/320671375737?pt=Automotive_Services&vxp=mtr&hash=item4aa980e179
I was looking at a closed system for cooling too, but the heat exchangers are $$$$$.
You know, if this works out good the short wide will be next.
blazeracer said:Regardless, whether I use a cable or DBW for the throttle, something has to be changed because the morse cable on it now is not going to work.
I remember what I wanted to ask. Your oil pan. Were you able to use a truck pan or did you have to get a GTO pan? I saw a thread somewhere where a guy did a LS conversion and the truck's rear sump oil pan hit the floor by the pump so he had to get a GTO front sump pan.
FormulaZR said:blazeracer said:Regardless, whether I use a cable or DBW for the throttle, something has to be changed because the morse cable on it now is not going to work.
I used a Camaro/Firebird pan. I did not have enough room to use a truck pan. The Camaro/Firebird pan is a rear sump, which I preferred.
On the cable - I hear you there, and am working on a solution for that. I *think* I may have something figured out...but will have to wait until I have the intake in my hands.
For DBW - the pedal is like that used in a factory truck/car, that bolts to the firewall area - not sure how to use that in my boat without it looking odd yet.
blazeracer said:This may work for the DBW pedal, then have to get a long A$$ wire to get the signal to the back.
http://www.ebay.com/itm/05-12-CORVETTE-C6-ACCELERATOR-PEDAL-DRIVE-WIRE-ALL-MODELS-FREE-SHIPPING-OEM-/170725076372?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item27c001ed94
Crusader said:blazeracer said:This may work for the DBW pedal, then have to get a long A$$ wire to get the signal to the back.
Are you going to remove that gas a$$ rinky dink pedal and put your cool hot foot pedal on it?
spd500 said:blazeracer said:This may work for the DBW pedal, then have to get a long A$$ wire to get the signal to the back.
That looks like it would be easy to adapt for the boat . Just get a nice cover made for the electric connections .
blazeracer said:spd500 said:blazeracer said:This may work for the DBW pedal, then have to get a long A$$ wire to get the signal to the back.
DBW just might be easier to adapt than getting the stock morse cable to funtion correcty. I may have some time to go diggin though pick a part tomorrow and look at some LS stuff.
BUt let's get this straight. If you switch to drive by wire I know you MUST have a DBW throttle body and ECM, anything else?
