Cable or wire should be easily achievable. For cable you would need to fab a bracket to go from Morris cable to a more flexible GM style cable. Should be a simple as a small plate with a bell crank. You could probably even start with a stock cable and cable mount from an F-body. It would have the right hole for the OE cable. There should be tons of those available in the yards. Add a stud on it with a bell crank and a Morris mount on the other end and boom your done. That could all be mounted in the engine compartment. As for DBW I would think those connectors are weather packs on the pedal side so it will be fine in the boat.
