vdrivegrimes
could you use factory manifolds run an exhaust pipe with a u-bend to act like a snail them rubber exhaust hose to the tips. maybe ceramic coat them to keep the heat down in the engine bay
You know what they say, if you cant beat them join them! :smile30:KONA said:Motor Head said:I guess the guys that designed the newer chevy motor for the cup cars realised that ford had it in the right spot all along lol!
:smile16: and it sounds like they copied the heads too.... crazy.gif
blazeracer said:http://dallas.craigslist.org/mdf/pts/2694988313.html think.gif
Last Mohican said:blazeracer said:http://dallas.craigslist.org/mdf/pts/2694988313.html think.gif
That would be sweet on my Avalanche.
blazeracer said:Last Mohican said:blazeracer said:http://dallas.craigslist.org/mdf/pts/2694988313.html think.gif
It would, but I don't think the rear end can handle that kind of power. It would be better in a jet boat. LOL
blazeracer said:Another question for Fomula. Would you have the guy doing the harness rewire put a 10ft (or whatever is needed) cable for the OBDII port so it can be connected up front and tuned on the water? Seems that would be a good investment.
Last Mohican said:blazeracer said:Another question for Fomula. Would you have the guy doing the harness rewire put a 10ft (or whatever is needed) cable for the OBDII port so it can be connected up front and tuned on the water? Seems that would be a good investment.
Just buy an OBDII extension cable.
http://www.obd2cables.com/products/cable-j1962m-to-j1962f-obd-ii-extension-cable-10ft.html
blazeracer said:Gen 3 engine
LS1 - 5.7L aluminum block, cathedral port heads
LS6 - 5.7L aluminum block, cathedral port heads - the block is different internally than the LS1
LR4 - 4.8L iron block, cathedral port heads
LM7 & L59 - 5.3L iron block, cathedral port heads
LM4 & L33 - 5.3L aluminum block, cathedral port heads
LQ4 - 6.0L iron block, cathedral port heads
LQ9 - 6.0L iron block, cathedral port heads, 10:1 CR
What vehicles had this motor??
blazeracer said:Matt, this is GREAT info. I hope you're not down for too long after your surgery.
spd500 said:I have been thinking LQ9 , is the LM4 a better fit for jetboat application ? Or do you mainly want the all aluminum motor ?
Motor Head said:Is there an all aluminum 6.0?
